Quadzilla carb on a LT250R? ?
Old Jul 29, 2004 | 03:18 PM
86LT250RFatty's Avatar
Default Quadzilla carb on a LT250R? ?
Hey im running the stock 34mm carb on my 86 Q'racer and saw this: Here On E-bay It says it should fit the Q'racer. Will this bolt right on? I have Exaust and Intake and i got port and polish so it should be verry affective right?
Old Jul 29, 2004 | 04:51 PM
Michwolv60's Avatar
i got a keihin pe 38mm carb i would sell you decently cheap, let me know. Thanks.
Old Jul 29, 2004 | 05:09 PM
Duneaddict's Avatar
It should help your top end performance quite a bit. Your '86 is a case reed right?
Probably won't help it as much as a newer model/larger reed cage version...
It may also hurt your bottom/mid range a little too... Depends on your riding style.
Be careful what year LT500 that carb came from.... If it was '87, pass on it. There were circuitry issues with the '87 carb that are expensive to overcome... If it's an '88+, you should be fine.
My $.02
Old Jul 30, 2004 | 01:16 AM
Why would i lose low/mid end??? it just has a bigger bore at full throttle. Hey Michwolv60 how much you selling for? and will it bolt up to my 86'? Also, did any company make exteneded A -Arms for the 85-86'? Cause i have about 200$ and wanted maybee some used ones.
Old Jul 30, 2004 | 07:02 AM
needaR's Avatar
why does your sig say you have a 36mm MIKUNI?and in ur page those arent "YOUR" quads.
Old Jul 30, 2004 | 01:27 PM
because i measured mine and its 36. and because im too poor to have a digital camera.
Old Jul 30, 2004 | 07:01 PM
Michwolv60's Avatar
yes it will bolt up, and give me 30 and shipping and its yours.
Old Jul 30, 2004 | 08:07 PM
Ill definatly buy that carb off you, please give me your e-mail so i can contact you. Ide give you mine but i get so much junk mail ide probobly miss it. Thanks. and im in NY
Old Jul 31, 2004 | 12:53 AM
Michwolv60's Avatar
Michwolv60@sbcglobal.net, let me know how u want it shipped and i will go get a quote, usps is the easiest for me, but i can also do ups. Let me know.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
