aftermarket air filters
Hey whats a good aftermarket air filter besides k&n that you guys are using.... and do u like em?? and how well do they stand up are they strong???
jeffroe is right, the K&N will out last all of
them and stands up to the true test
some real riding.. easy to clean and alot stronger
out of the box no-toil might flow better
but after a while when your cleaning the foam all the time
and they are retested for flow K&n is hands down better
drag racing go no-toil, real riding and durability k&N
so the K&N is actually good on the ds650 but i sure had bad experiences with em on my warrior the foam seal on the air filter always ripped and came apart no matter how carefull you were with them then if u didnt check them and it was ripped or comming unglued your engine prob be gone so thats why i didnt want K&N again.
sounds like bad luck, my friend has had one on his 86 350x forever
cleans it once in a while but it has to be over 8 yrs old
should get a new one but it still working thats the point
So, K&N with or without the pre-filter? Can this be used instead of the stock filter setup without rejetting or any other adjustments? What if any performance difference is there with these filters from the stock setup?
Thanks,
Kaz
Thanks,
Kaz
