water
Old Jul 30, 2004 | 01:47 PM
400sEXridr's Avatar
Default water
wut is the very worst thing that could happen if water got through my air filter and how much would it cost to fix it. It's not like it was a continuous flow, but just drops here and there.
Old Jul 30, 2004 | 03:41 PM
KajunATVer's Avatar
Default water
Check the oil and if it's milky then water got in the motor. Just change the oil and filter until the oil is clean and all the water is out of the motor. Also, you may want to drain the carburetor bowl to get any water out of the carb. I really wouldn't worry about it much. I have drowned out my Foreman many times and all I do is dry out the air filter and drain the carb and it fires right up. After I get home I'll change the oil a couple of times to get the water out of the motor. It still runs like a champ even though it's been drowned out a few times. It has even been floating upside down in a river after I hit a deep spot and doesn't smoke or anything.
Old Jul 30, 2004 | 04:12 PM
400sEXridr's Avatar
Default water
it still fires up ok but runs a little rough. How many times did you have to change the oil?
Old Jul 30, 2004 | 04:14 PM
KajunATVer's Avatar
Default water
Until all the water is out (until the oil isn't milky any more). As far as running rough, draining the carb. should fix that.
Customer Service #1
May 15, 2020 08:46 AM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
