Ground clearance
Old Jul 30, 2004 | 04:14 PM
Moonpie's Avatar
Default Ground clearance
What is the best way to lower the ground clearance on an Arctic Cat? It has a tendency to role when turning corners. Tires are stock Carlisle 25x10x12 & 25x8x12.
Old Jul 30, 2004 | 04:32 PM
ng's Avatar
ng
I think the biggest problem is the tires,My Rincon did the same thing until I put Mudlights on,It really helped.
Old Jul 30, 2004 | 04:36 PM
Moonpie's Avatar
Same size tires? If so, why do the mudlites help? Thanks
Old Jul 30, 2004 | 04:59 PM
700vtwinman's Avatar
A friend of mine has an AC650 vtwin and it did the same thing with the stock tires. He put 27" ITP 589s on it and that solved probably about 90% of the problem according to him. He said it makes all the difference in the world.
Old Jul 30, 2004 | 05:58 PM
Moonpie's Avatar
Would ya'll recommend 26x10x12(front) and 26x12x12(back) in a mudlite, gator, 589, dirt devil, or something else?
Old Jul 31, 2004 | 12:12 AM
heyyou's Avatar
What size bike?
Old Jul 31, 2004 | 04:20 AM
Andy Bassham's Avatar
I don't get this. You want to lower the quad's ground clearance, but you are talking about taller tires. Do you just mean making it more stable? If so, I would guess a wider setup and tires with a stiffer sidewall.
Old Jul 31, 2004 | 07:46 PM
mudblaster's Avatar
try ajusting your shocks to a stiffer setting.
and 26x10x12s and 26x12x12s will work great.
i set the shocks to the stiffest setting and with the bigger tires it was very stable.
and i would go for the gators thay worked great on my 500.
Old Aug 2, 2004 | 12:19 AM
weez440's Avatar
look in the back end of the atv there is differnt holes where you can unbolt your a-arms and bolt them up so you get less ground clearance but i put 27 inch itp 589's on mine and it made a world of difference the two biggest factors were the aftermarket tires are wider and they are way heavier well and plust a stiffer sidewall you won't know your machine back after a tire change and i left the shocks settings the same
Old Aug 2, 2004 | 02:39 PM
swampyjunior's Avatar
Roll in the corners, on hill sides, any time your weight is distributed sideways, hell yeah its down right scary. Rolled my AC 400 over 5 times now. Two of those times I thik were the tires fault. Thank God I was never injured but as soon as my mudlites get here I am cutting them off with a knife and throwing them away.
I rode another AC 400 with 26 inch mudlites and I thought it was a different bike. I was able to do a few things that would scare the crap out of me on my 400.
With stock tires I was not able to find a spring setting that stopped the roll in the corners. But I know changing the tires will almost eliminate it entirely.
I believe the reason why it helps is that on the stock tires they are a 2 or 4 ply tires. Not much support for the sidewalls. The mudlites or similar tires are 6 ply tires. Similar to truck tires. More ply ratings increases the load range and stiffness of the side wall of the tires.
