yes, another jetting question for banshee....
Old Aug 1, 2004 | 07:32 PM
fourjs's Avatar
Default yes, another jetting question for banshee....
01 banshee, ported, milled, reeds with spacers, 320 mains, clip third position, stock carbs with toomey 2-1 air cleaner, spark plug check looks fine in all areas of throttle position, my question is the bogging of start when racing, after bogs, runs like lighting, are mains to big or do i need larger carbs? have tired smaller main jets (310, 300) still have bog problem but it also has it on top, 320 took care of problem on top, tried different clip postions and third came up best place, any ideas,
thanks..........
Old Aug 2, 2004 | 07:04 AM
enFORCER's Avatar
Might be your port work, the more you open up the exhaust ports the more bottom end you will lose.... But its runs much better on top end..... Did you have drag porting done?
Cole Hadden
Jun 15, 2025 09:05 AM
Kaleb_00
Jun 1, 2016 09:15 AM
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
