oil filter
Old Aug 15, 2000 | 11:46 PM
blasterguy's Avatar
does a bayou 220 have a oil filter and if it does where is it at and how can i change it, do i have to take off the case to get to it,i hope not the 220 i am buying probbly has never had it changed before.
thanks
1987 kawasaki mojave 110
2 1986 trx 125's (both broke)
1990 kawasaki bayou 220
Old Aug 17, 2000 | 12:43 PM
drlaney's Avatar
The Bayou 220 has both an internal filter screen and conventional type filter. The internal screen should only be cleaned when the engine is torn apart and is there only to save the sump pump from larger metal fragments. The conventional filter is located behind a black, circular cover near the lower front of the right (as if you are sitting on the ATV) side of the engine. It is kept in place my two 8mm (if my memory is correct) bolts and should be replaced after every five tanks of gas.
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
