DVX400 jetting help!!!!!!!!!
Old Aug 5, 2004 | 05:13 PM
DVX420's Avatar
Default DVX400 jetting help!!!!!!!!!
I bought a quadworks kit on ebay for my 04 dvx400. It comes with a K&n filter, prodesign adapter, and a stage 1 and 2 dynajet jet kit. I installed the filter and adapter two days ago. I have to go with the stage 2 jet kit because I want to run an open airbox with no end cap. Dynajet calls for a 146 main jet in their instructions. I called them this morning and they said because of the prodesign adapter you have to use a 160. I installed it and turned the air/fuel mixture screw back 3 turns. I also have their needle and eclip installed in the 3 position. I fired it up and it idles fine until operating temperature and then it gradually slows down and then finally dies on its own. Should I mess with the air/fuel screw? Or should I change the position of the needle? Also when you go to start it, do you keep the fuel switch on prime at all times or just when you're starting it? Please help, Any advice will do. Thanks.
Old Aug 5, 2004 | 09:47 PM
rolsmojave3's Avatar
i would say maybe the mixture screw as my mojave did that until i messed with it
just turn it either way and see what has better results
with the 160 is it too rich you should check the plug to make sure
Old Aug 5, 2004 | 09:49 PM
chazekxt's Avatar
no do not leave it in the prime pos. u dont really need a jet kit to much money. i have hmf slip on 165 dino jet in mine air screw out 3 turns stock needle white bros air filter it and no lid it pulls vary hard.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
