Popping Noise?
Old Aug 8, 2004 | 09:10 PM
thebutelr's Avatar
Default Popping Noise?
Just the other day i was out riding my 350x and it started making a popping noise in the back end, i took it in the shop and checked my engine mounting bolts and a couple were loose so i tightened that and my swing arm bolt and it stopped for a little while. Well i got out riding today and it started the same crap again only this time it was worse, i checked my mounting bolts again and found two bolts missing from the rear hanger plate that holds it on the frame, is this whats making my bad popping noise? I'm totally stumped on this one cuz i can't find anything else that it could be, oh yeah my rear bearings are pretty well worn too but i don't think that would cause all that popping. Any ideas?
Old Aug 9, 2004 | 04:32 PM
ThrashAndCrash's Avatar
Check your:
Rear hubs
rear tire lug nuts
Swingarm bushings
Get them axle bearings fixed pretty soon, if they come apart in there you will wish you did it sooner, and when you do PACK them with greese, even if they are the sealed type, pop out the plasctic ring, and pack them full, THEY come with a very little amount of greese in them and they will go bad Quick!
Old Sep 6, 2004 | 03:11 AM
250x350xconversion's Avatar
check your chain. you may have to much slack in the chain and it is probably jumping teeth
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
mrtidy
Feb 3, 2016 05:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
r1pilot83
Sep 27, 2015 07:38 PM
