240 carb
im gettin the vitos 240 kit and i want that carb that you can adjust the jetting with the ****. i saw it in one of the mags. it was a 35 i think but when i looked online it doesnt show it. also is the head for the 240 bigger than stock b/c idk if it will fit with the LRD pipe cause its only about 1 cm away from the head now
thanks for any help
thanks for any help
From the outside, The cylinder is the same, the only thing bigger on the 240 is the sleeve.
I strongly suggest that you check out some of hollywood dirts stuff before you decide on vitos...Are you getting the ported kit, or the one with stock-porting?
As for the carb, the best size to run would be between 30-35. I will be running a 33mm carb, but thats with a heavily ported cylinder.
You can buy the carb adjustment from a company called thunder products.
http://www.thunderproducts.com/
It can be installed into any carb. With this you still need to jet. All it does is adjust for the minor changes in elevation and tempature.
GregM
Mar 6, 2018 06:53 AM
