Need Help on my Raptor
Old Aug 14, 2004 | 03:35 PM
SkoolBoy's Avatar
Default Need Help on my Raptor
My firend was riding hes 03 raptor and i was riding my 05 raptor and we were climbing good size hills. My friend in his 03 lost it on the hill and he ended up bailing off to watch hes Rap roll 2-3 times down the hill...we got it back up and it started right up but when you try to give it gas it wants to die and backfire. Almost exactly what it does when you start a cold raptor..we changed spark plugs and its still doing it...Any suggestions ill try anything
Old Aug 14, 2004 | 04:02 PM
2's Avatar
I had the same problem on my brothers 03 limetid edition raptor.
my first suggestion is cleaning the carberator or your idol is to high.
Old Aug 14, 2004 | 04:16 PM
1LeSSRaptor's Avatar
You may want to check out the emergency brake lever. From all of that tumbling, it may have bent the lever and there is a rev limiter switch on the perch that prevents you from giving it gas when the e-brake is engaged. Make sure that the switch is getting contact. Hopefully, it's a simple fix like that.
Old Aug 14, 2004 | 06:20 PM
440grl's Avatar
You also might want to see if your carb boots came off or if your jet's came loose....rolling can make alot of different things happen. Just go step by step in your diagnosis and you will find it..... sounds like it's getting TOO much gas and not enough air.....
Old Aug 14, 2004 | 11:00 PM
raptorblasterracer's Avatar
my frineds carb actually fell of a lil bit n it was enough to @$$#@ it up so make sure ur carbs r on nicely
Old Aug 15, 2004 | 03:47 PM
HughJazz's Avatar
Sounds like the park brake too me. Check the wiring to see if anything is unplugged behind the rad. A friend rolled his and pulled the wires for the ignition switch out.
Old Aug 16, 2004 | 04:18 AM
SkoolBoy's Avatar
Hey got it fixed, thanks for all your help..it ended up being the ebrake switch we ended up cutin it off and taking away the conntacts..works like new...thx everyone
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
