blaster problems
Old Aug 15, 2004 | 11:22 PM
Yamahaalltheway's Avatar
Default blaster problems
i have a 2004 blaster with fmf sst exhaust. the other night i was teaching my sister how to drive it and we were putsing around. i went to clear the engine down a gravel flat and it killed. i couldnt get it started again. there was gas. and the next day i had it started for 30 seconds top and it killed and couldnt get it started after that. i checked the plug and its not that. i cant figure it out please help oh ya and i cleaned the air filter and its not that.
thanks ben kernen
Old Aug 15, 2004 | 11:26 PM
UnWSpLaT's Avatar
u smell gas at all?
Old Aug 15, 2004 | 11:33 PM
Gills04yfz's Avatar
u check the carb? it might not be gettin fuel
Old Aug 16, 2004 | 01:24 AM
daputz's Avatar
Have you done a compression test on it?
Old Aug 16, 2004 | 01:58 AM
Sandfox24's Avatar
My Blaster had a problem every time you would turn the handle bar to the left (even just a little bit) it would die. There was a short in the wires on the steering stem.
Old Aug 16, 2004 | 03:57 PM
Shav0's Avatar
Try changing the plug. If you were teaching someone to drive it, and they were going fairly slow, then you might have fouled the plug. Change it and see if that helps.
Frisky2050
Apr 9, 2020 11:19 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
joeyupton
Jul 14, 2015 11:51 AM
