warrior sprocket ?'s
Old Aug 16, 2004 | 11:18 AM
2phast4u2catch's Avatar
Default warrior sprocket ?'s
on my warrior i have 12 41 gearing and i do alot of trail riding and w/ this set up i dont notice very much tourqe wat should i do?
Old Aug 16, 2004 | 11:22 AM
Warrior350ripper's Avatar
with a 12t front that should do the trick.maybe u need a rebuild?.i don't know
Old Aug 16, 2004 | 11:28 AM
NLWarrior01's Avatar
I find plenty of torq even with my 15/40 gearing .. it's not a punchy as when i got my 12/42 on, but still pretty good.
12/41 should be plenty of torque .. with 12/40 I could lift the front in 4th with only modest effort.
Old Aug 16, 2004 | 12:01 PM
should i go down to a 38 in the rear? and if u think i need a rebuild where can i get the parts to do the rebuild and what would the price be?? thanxs
Old Aug 16, 2004 | 12:08 PM
ss97's Avatar
Lets Ride!
I just dropped from 15/40 to 13/40, but I didn't notice that I was having any torque problems with the 15/40. I changed to stock for a couple reasons. I ride mostly woods and trails and never need to do 65-70mph (which is a guess at top speed with a 15/40 set up). A Warrior with the stock 13/40 gears will do 55-58.
But I can't imagine why the gearing would have an effect on your torque, it should still be there no matter the gearing. The only thing that should change is the top speed, the acceleration and which gear you use for certain things.
An example is hills I needed 1st gear with 15/40 I can now climb in 2nd with 13/40.
Are you lacking torque compared to what you used to have?
Old Aug 16, 2004 | 01:03 PM
The gearing doesn't change the actual torque. It's more a torque multiplier type setting, and enhances the application of the engine's turning force.
A Warrior with stock gearing will easily go over 60 unless uphill against a wind with a heavy rider. 15/40 with the appropriate engine mods (i.e. 435cc kit or such) will go over 70, but it takes some ***** in the engine work to get that fast ...
Old Aug 16, 2004 | 01:55 PM
Gwinnwarrior's Avatar
you probably arent nopticing alot of torque because once you hit the gas with that 12 on the front its already at peak RPM. go up a few teeth and see what you find. i got a 15 tooth front and its working sweet for me right now.
Old Aug 16, 2004 | 09:58 PM
i just bought a 13 tooth front sprocket but now how do i put it on i didnt buy a 14 or 15 bcuz i dont have the money to buy a new chain
Old Aug 16, 2004 | 11:50 PM
04Raptor350Guy's Avatar
I thought it came stock 13...?
Old Aug 17, 2004 | 06:45 AM
[quote]
Originally posted by: 2phast4u2catch
i just bought a 13 tooth front sprocket but now how do i put it on i didnt buy a 14 or 15 bcuz i dont have the money to buy a new chain[/]
I have 15/40 with my stock chain. I was going to go with 15/42 because I thought that 15/40 would just be too tall, but with the 42T my chain was just a touch too short. I'd say with some presuasion [img]i/expressions/face-icon-small-wink.gif[/img] your 15/41 combo would work. Besides, front sprockets are cheep even here .. like $10 each [img]i/expressions/face-icon-small-happy.gif[/img]
When I redo my bearings I'll be stepping back to my 12/42 setup, and back into my jetting experiments.
