swing arm bolt... HELP PLEASE
Old Aug 20, 2004 | 03:05 PM
orky4969's Avatar
Default swing arm bolt... HELP PLEASE
The front bolt on the swing arm of my warrior will not come out. *the one closest to the engine* It's like frozen in there, and i was wondering if any one had any idea of getting it out.... I heard about the same problem with the 400ex's...... Please help ASAP as i'm trying to fix it now.
thanks...
Old Aug 20, 2004 | 06:19 PM
warmdye's Avatar
give the threaded end a nice wack with a hammer and screwdriver or 2x4. Thats how I got the one out of my old tecate 4
Old Aug 20, 2004 | 07:07 PM
HA2's Avatar
HA2
650lbs of torque will do it. impact wrench that is.
Old Aug 21, 2004 | 12:31 AM
fourtrax250x's Avatar
put some liuid rench on it that will help penatrate all the surface rust and help lub the threads
Old Aug 21, 2004 | 01:08 AM
KGB's Avatar
KGB
If its bad, you could be screwed. many people have had to cut it out. Soak it, hit it, spin it, if you get the BFH and mushroom the head its just about saw time.
Good luck.
EDIT: remember if its stuck in there, you need a new, one, so do what it takes to get it out, your going to mess the bolt up.
Old Aug 21, 2004 | 10:09 AM
thewayout420's Avatar
is there locktite on it?heat it up with a torch a little..
Old Aug 21, 2004 | 12:26 PM
odysseyjunk's Avatar
yeah before you hammer on the threads, use an air gun to break it free and get it spinning, if it wont move, get a bigger air gun and max out the pressure regulator....it will eventually spin (or break). when you get it spinning, while its moving with the air gun, tap the thread side with a hammer. try not to mushroom the threads though, thats a silly way to waste the bolt. well, good luck, a torch is the best way to break it free, but i dont evenhaveone of those inmy garage, and ive got lots of tools.
fd24
Jan 16, 2019 08:59 AM
toonces
Aug 21, 2015 01:19 PM
Jul 28, 2015 12:12 PM
Bell21
Jul 28, 2015 06:52 AM
c400ex1234
Aug 14, 2000 05:17 PM
