make your own three headlight conversion kit
Old Aug 21, 2004 | 07:22 AM
silverbullet2005's Avatar
Default make your own three headlight conversion kit
these directions will allow you to build your own headlight conversion kit to allow you to use the two lower headlights with the low beam activated and allow all three lights to turn on when the high beam is activated. the wire colors are for polaris but the kit will work with all quads with three headlights.
the parts you'll need are as follows:
6 amp. rectifier/diode(radio shack part number 276-1661)comes in pkg. of four.
6" of yellow wire
6" of green wire
heat shrink connectors or butt connectors
heat shrink tubing.
2 scotch lock connectors
start by using the heatshrink/butt connectors to connect the colored wires to the diode. if using the diodes from radio shack the green wire will connect to the end of the diode with the silver stripe while the yellow wire will connect to the black end of the diode. use heat shrink tubing to cover the connections and diode from moisture and dirt. use the scotch locks to connect color coded wires to headlight wires in factory harness. this harness is located under the gauge pod. green to green and yellow to yellow.
If using diodes other than ones from radioshack make sure flow goes from green wire to yellow. this will allow current to flow through green(high beam) wire and over to the yellow(low beam) wire while the high beams are on.
*****this "kit" was discovered by other forum members and is now being passed on to you for free so we can all stop making those freekin ebayers rich off of $3.00 worth of supplies.*****
Old Aug 24, 2004 | 12:51 PM
please let me know if any of you made a kit and how it worked out for ya.
Old Sep 24, 2004 | 09:47 PM
410stroker's Avatar
Thanks for that info I was trying to find it for a couple weeks now .It worked like a charm . for those who havent done it I recomend it and just remember its the wires that come down of the Hi/low beam switch into the gauge pod [img]i/expressions/face-icon-small-smile.gif[/img] and they are solid colors not striped . thanks again
Old Oct 8, 2004 | 12:19 PM
no problem, thanks for your reply so all the other guys thinking of making their own know it works.
Nazz26
Jul 30, 2015 11:51 AM
KingDingalling
Jul 29, 2015 10:55 AM
kodiak450.
Utility ATVs
13
Jul 27, 2015 05:07 PM
JoAnnS
Jul 23, 2015 02:18 PM
Captjay
Jul 23, 2015 12:33 PM
