Back-up light???
Old Aug 21, 2004 | 09:53 AM
1der's Avatar
Default Back-up light???
Has anyone installed a back-up light on their machine? Cabela's shows one but dosen't mention that it goes on when in reverse. (has a switch which I'll forget to turn off). Woods&Water has one that they claim goes on <u>when</u> in reverse and has a switch. The switch will come in hand when I load that monster buck this fall.
Old Aug 21, 2004 | 10:47 AM
thewayout420's Avatar
just add the power wire for the light to your reverse dummie light and it should come on whenever you put it into reverse
Old Aug 21, 2004 | 10:49 AM
SPORTSMAN70003's Avatar
On my 700 there was a white wire under the hood that grounded when you pull it in reverse. So all you do is hook the positive wire to your battery or solenoid I put mine to the solenoid and hook your ground wire to the white wire your done. hope this helps
2003 POLARIS SPORTSMAN 700 TWIN
MODIFCATIONS
1.SUPER DUTY HIGHLIFTER CLUTCH
2.AAEN EXHAUST
3.27'' GBC GATORS
4.DYNOJET KIT
5.REVERSE LIGHT
6.CUSTOM NERFBARS
7.FRONT BRUSHGAURD
8.REAR TUBE BUMPER
9.2500 LB RAMSEY WINCH
10.POLARIS HANDGAURDS
11.GEL GRIPS
12.FUEL GAUGE
13.K&N AIR FILTER
14.3'' WHEEL SPACERS
15.HEADLIGHT MODIFCATION
16.REVERSE OVERRIDE MODIFCATION
17.COIL SPACERS
Old Aug 21, 2004 | 10:51 AM
if you can do what sportsman said,that will be the way to go[img]i/expressions/face-icon-small-smile.gif[/img]
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
