New-be question about suspension
Old Aug 22, 2004 | 11:23 AM
jw02's Avatar
Default New-be question about suspension
Planning on buying this week. I have a question about the independent rear suspension. How does the Honda type (one spring) compare to a real independent suspension like the Arctic Cat. I will be using in a very rocky and uneven surfaced area. Which would be better in that type area?
Old Aug 22, 2004 | 05:17 PM
Carmelo15's Avatar
for rock crawling i would think the IRS is better as compared to SRS because with IRS when one tire goes over an obstacle the other tire isnt bother as much therefore staying more planted on the surface. with SRS when one tire is doing something the other tire is largely affected because they are directly connected. now if you were to do any high speed riding i would suggest SRS because there is less body roll and the quad will slide easier than the IRS quads. hope this helps
Old Aug 22, 2004 | 09:03 PM
Vaquero's Avatar
For the rocks I would go with the IRS. Either artic Cat or Polairs see which fits you better and whitch has a better low range.
1ArmBandit
55
Oct 14, 2015 09:03 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
Bigtwin700
Sep 9, 2015 09:32 AM
Rooky
Sep 9, 2015 03:16 AM
chewy78
Sep 8, 2015 10:37 AM
