Chain please help
Old Aug 22, 2004 | 03:27 PM
RickyD650's Avatar
Default Chain please help
hey everyone yesterday night i was ridin my ds in the woods and heard some clacking nosies from the chain now i don't have a manual cause i bought it used and they did not have one but anyway i need to know how to tighten the chain i searched other topics but none were specific enough please help me thanx
Old Aug 22, 2004 | 03:43 PM
DuneMe's Avatar
Since yours is a 2000 I would check a few things. . .
Check your countersprocket (front sprocket) for wear. It may be time to replace it. If the rear has been changed to an aluminum one it probably needs replacing too.
Check behind the sprocket for oil leaks. You may need to replace your oil seal on the countersprocket shaft. This site has some great info.
To answer your question on adjusting the chain - loosen the bolts on the back of the swingarm so the bearing carrier can rotate. The bearing carrier is egg shaped so if you rotate the lobe towards the front of the bike, the chain gets tighter. Don't go too tight and you should probably have someone check the tension with you on the bike.
Also, you may want to remove the axel and lube the bearing carrier - probably best to replace the bearings and seals and lube the crap out of it.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
