Wires to the throttle assembly?
@ are for the AWD switch and the other 2 are for the ETC. Or the switch on the throttle that says the throtle is stuck and it stops sending a signal to the CDI causing the motor to start skipping and slow down. Its a safety thing in case the throtle sticks.
After the TMX flatslide Ive never had a stuck throttle slide. So would it be better to cut the wires of at the connector or pull the joint out and silicone in the hole to keep dirt out?
