Gas Tank Vent
Old Aug 23, 2004 | 06:38 PM
AZhighRIDER's Avatar
Default Gas Tank Vent
I used silicon to block off the vent for my gas tank, i vented it from the top of the cap, will silicon get into my gas tank and screw things up or what??? if silicon isnt a good idea, what is? Thanks...
Old Aug 23, 2004 | 07:43 PM
thewayout420's Avatar
why did you change the vent line location?
Old Aug 23, 2004 | 09:15 PM
tbsleeper's Avatar
prob cuz it looks cooler, atleast i think it would
Old Aug 24, 2004 | 06:22 PM
I had to cause that tiny little vent wasnt letting the pressure out and my bike would always die on me...(also it looks cool) plus i usually run 110-116 octane fuel...
Old Aug 24, 2004 | 09:45 PM
DGpolaris2346's Avatar
I also put the vent line on the gas cap and plugged the other vent line. If you would like pics IM me on aim at icptwztdkkabk or PM me with your email.
Old Aug 24, 2004 | 10:22 PM
PINKMOON's Avatar
Hi I also was forced to drill out my gas cap and use a larger gauge tube to alleviate the pressure in my gas tank. I did not block off the old factory ( crappy too small ) vent. I now have it plus the gas cap tube I installed myself. Is there a real need to block off the old factory vent tube after installing a gas cap vent tube ?
Old Aug 24, 2004 | 11:36 PM
NBsportsman's Avatar
Hey fellow New Brunswicker, I was haveing vent problems on my Sportsman. The tank would build up pressure and spray gas out of the vent line. I looped it up high in the pod and put an extention on it and ran it down the frame. If that doesn't work I'll put one on the cap and leave the factory one too as more air is better......
Old Aug 25, 2004 | 12:15 AM
yammaslamma's Avatar
yeah would u HAVE to plug the stock one?
Old Aug 25, 2004 | 01:40 AM
MrZeeedler's Avatar
Just go down to your local mx shop pick up a gas cap with the vent line on it.
Old Aug 25, 2004 | 07:58 AM
No you don't have to block off the old vent.....
