Ported intake
Old Aug 26, 2004 | 11:22 PM
TheChosenOne's Avatar
Default Ported intake
I ported my intake, I am about to put it in for a test run. I removed the bump inside, and enlarged the intake a bit. I left it pretty rough, just used a small grindstone bit on the dremmell to finish it up. I am wondering just how rough or smooth this thing is supposed to be in the end. I will probibly put this thing in and take it out several times trying several combos. If anyone has any questions they have been wondering, ask me and I'll try to do it and test it for you. I want this experience to help all of us be able to do something like this. Like I said, my only question to you guys is the ballpark guess on how rough it needs to be. Thanks and hope to learn from this.
Old Aug 26, 2004 | 11:42 PM
DuneRider650's Avatar
I ride a little here and there......
it should be pretty smooth more smooth than ruff i would think
Old Aug 27, 2004 | 01:30 AM
After my test, I figure rough is good. I know smooth is bad, causes too much friction in the intake for the air passing through. Roughened up a bit, it permits "pockets" of air to become "trapped" along the sides of the intake therefore reducing the friction for the remaining air to pass through. Also, the roughness aids atomization of ate air and fuel.
With my ported intake, it now starts much easier, idles smoother, and uber power. LOL I'd agree with everyone else this is a must have mod, and it's easy to do yourself with the right tools and ample time. Just don't rush.
Old Aug 27, 2004 | 01:46 AM
lol well i guess i no absolutely nothing at all bout porting. But i might have to try this out sounds like a good way for a lil more power
Old Aug 27, 2004 | 07:04 AM
Freez's Avatar
Did you remove the whole bump inside the intake? What is it used for anyway? I remember seeing the bump, but never looked closer to what is it there for.
Old Aug 27, 2004 | 09:06 AM
Bellracing2's Avatar
It's a dent in the casting for clearence on the top mounting bolt .
Old Aug 27, 2004 | 10:04 AM
abaran's Avatar
I'm fairly new to the atv world, but I've modded several high end sports cars. Now in theory the way it works is the more air flowing in and out of the engine, with the right mixture, the more hp you have. Normally you want the intake as smooth as possible to create less friction and more air flow. Again, maybe it's different on an atv, but I wouldn't think so.
Colin
Old Aug 27, 2004 | 12:07 PM
sam's Avatar
sam
I do belive you would want the intake tracks smooth for a certian fuel injection motors ( i could be wrong) cause there is no fuel passing through the intake trac just air. but the reason for some texture on the DS intake is to assist the fuel atomizing as it passes through the intake. some here smothed the intake and couldnt get there quad to start, rough it up a little and started fine.
Sam
Old Aug 27, 2004 | 12:18 PM
shmee's Avatar
why does everyone think you have a ruf surface on the intake to mix the fuel and air?? for my two cents the carb does all of that. so get it as smooth as you can!
Old Aug 27, 2004 | 12:26 PM
Prozack's Avatar
"smooth" yes ... But just dont polish it.
