Running horrible-Sportsman 90
Old Aug 27, 2004 | 12:27 AM
HotShot90's Avatar
Default Running horrible-Sportsman 90
Our sportsman 90 is running bad. it is acting like the jets are blocked up, but ithey aren't. i took the carb of and look, nuttin. this has happened 3 times already, and i can't figure out whats a matter. every time we take the carb of, it works soon as we put it back on. is it not getting air intake or compression? we checked all the gas lines. perfectly clear.
Old Aug 28, 2004 | 11:01 AM
SANDMAN430's Avatar
a friend of mine said they had a similar problem said there was some thick oil in the carb for shipping took a while to get it out.
Old Aug 28, 2004 | 06:14 PM
elraptor02's Avatar
maybe there is gunk in the bowl making the float stick..which in return is letting to much gas into the carb making it bog down and not run well
Old Aug 29, 2004 | 12:07 AM
MikeCer's Avatar
have you checked your spark plug, my daughters was running bad and finally died out on the trail and wouldnt start, spent about an hour checking different things finnaly ended up driving back to the truck and getting a new spark plug once we replaced the spark plug it ran great and havent had a problem with it since, now we keep an extra spark plug with us when we go out....... It was getting spark but it was very weak compaired to the new one..
Spark Plug Gap .24-.28in/.6-.7mm
NGK BP7HS or BPR7HS
Autolight 4123
I havent found any of the NGK's where I live, so I've been using the autolites, and they are pregapped, atleast the one's I've purchased..
Old Aug 29, 2004 | 01:52 AM
WhoDatInDaMud's Avatar
Had simular problems. Once it was the jets which fooled me at first but a thin wire would not push through it.
Second time it was a loose spark plug wire where it pluged into the 90degree elbow / socket
Old Aug 29, 2004 | 10:48 AM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
What exactly is it doing?
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
