hard starting 98 warrior
Old Aug 28, 2004 | 11:37 AM
brianpala's Avatar
Default hard starting 98 warrior
I HAVE 98 WARRIOR THAT DOES NOT WANT TO START EASILY. CRANKS AND CRANKS THEN FINALY SHE WILL FIRE. IT APPEARS TO POP START EASY. (W/N A COUPLE OF FEET WHEN BEING TOWED). COULD IT BE A SHORTED OUT NEUTRAL SAFETY SWITCH, THE ONE ON THE CLUTCH HANDLE. NEUTRAL LIGHT DON'T WORK. MUST START WITH CLUTCH IN EVEN WHEN IN NEUTRAL.
Old Aug 28, 2004 | 01:15 PM
warrior68man's Avatar
Your using the choke correct? Does it do this even after it's warmed up?
Old Aug 28, 2004 | 01:54 PM
brianpala's Avatar
yes... and yes *no choke when already warm*g
Old Aug 28, 2004 | 01:57 PM
TrailBlazerguy250's Avatar
hmmm do you have any mods on it ?
Old Aug 28, 2004 | 02:08 PM
brianpala's Avatar
it's not mine, i'm just doing work for a guy.... as far as i know there is nothing aftermarket other than, a rebuilt starter, new solenoid, new everything for starting as everything was shot... so i think i hvae figured out, that the neutral safety switch is not allowing it to start. i unplugged it from down under the motor, and up by the clutch... it fires right up now.
Old Aug 28, 2004 | 02:21 PM
brianpala's Avatar
does that make sense to anyone
Old Aug 28, 2004 | 02:25 PM
brianpala's Avatar
the true test will be when it cools and try it.
Old Aug 28, 2004 | 02:49 PM
yeah makes sence
Old Aug 28, 2004 | 02:51 PM
i bet thats it
MikeyBoyesq
Nov 27, 2020 02:44 PM
chinkapin
Jul 14, 2016 06:58 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
1000gade
May 27, 2015 12:37 PM
