Blaster carb and reeds
Old Aug 28, 2004 | 10:44 PM
Dr89's Avatar
Default Blaster carb and reeds
You can see the mods i've already done but i was wonderin bout gettin a trenga racing 30mm flatside carb along with the trenga reed spacer and boyseen reeds. how much with the carb help me throught out the power band and will it be worth the $170. how will it work with the reed and spacer set up. most important to me is bottom end power which is y i chose boyseen reeds. also bout wht jet will i need to run...i've currently got a 250 main stuck in there. thanks for the help
Old Aug 28, 2004 | 11:09 PM
Ernie660R's Avatar
I would suggest calling William at 1Dirracing @ 858-679-3288. He will steer you in the right direction. He has helped many guys on the forums.
Frisky2050
Apr 9, 2020 11:19 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
joeyupton
Jul 14, 2015 11:51 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
