air/fuel mixture screw
Old Aug 29, 2004 | 10:15 AM
400sEXridr's Avatar
Default air/fuel mixture screw
what exactly does this control? I have mine set on 3 turns out like HMF said, but my friend who has an HMF full system like me, with a hot cam stage 2 and a higher compression piston (not sure on the exact compression) has his 2 turns out. They both seem to run ok, other than mine shoots flames occasionally. Could the cam and the piston mean the difference in this?
Old Aug 29, 2004 | 11:32 AM
TractorPacker's Avatar
Do you have a balloon?
The cam will make a difference in jetting. Blowing a flame is normally from too rich of jetting. The air screw controls just off idle to quarter throttle. Try turning the screw in a little at a time and see if it starts to run better.
Old Aug 29, 2004 | 01:31 PM
Ozark38's Avatar
Maybe your friend is running a bigger pilot jet and/or moved the needle clip in a lower slot. Either of which would require less turns out on the air/fuel screw.
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Beeline08
Nov 11, 2016 04:00 PM
Oct 10, 2015 10:20 AM
Jackg17
Sep 26, 2015 09:30 PM
