rubicon blinking between 4th and 5th gears
Old Sep 1, 2004 | 06:17 PM
adogg's Avatar
Default rubicon blinking between 4th and 5th gears
I have had a problem with my 4 wheeler (2001 rubicon). When I use ESP, after 4th gear and going into 5th gear, the display starts blinking --, and it will not transfer into 5th gear. It will not shift to any other gear at this time until use turn the switch off. It does not start missing or running wrong at this time. If I am in D1 or D2 it will just not go into 5th gear, I note that because it does not go above 45 miles an hour. Thanks for your help.
Will
Old Mar 25, 2005 | 02:10 PM
YBRubi's Avatar
Hi, I am having the same problem on a 03 Rubicon, but it wont go more than the 3rd gear...and the display its blinking all the time....I cant go more than 20 mph....what dou you suggest? is there a code to reset or something? thanx for the help in advance....
bzdok1234
30
Feb 23, 2016 01:55 PM
John Reed
Sep 9, 2015 03:46 AM
awer1968
Sep 8, 2015 11:02 AM
bzdok1234
Utility ATVs
Aug 21, 2015 10:11 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
