450r Transmission Oil change
Old Sep 1, 2004 | 06:33 PM
450rNate's Avatar
Default 450r Transmission Oil change
Just changed the tranny oil today for the first and the gears feel real slippery, that will go away won't it?
Old Sep 1, 2004 | 08:36 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
What do you mean the gears feel slippery? Do you mean the clutch is slipping? If you used the right oil your clutch shouldn't slip at all after an oil change.
Old Sep 2, 2004 | 10:04 AM
450rNate's Avatar
I used Honda GN4 10W40.
Old Sep 2, 2004 | 10:13 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I would suggest you try Honda 80W/85W HP Trans Oil in your transmission. That is what 250R and 2-stroke dirt bikers have use for years.
Old Sep 2, 2004 | 10:20 AM
450rNate's Avatar
I was just following what it said in my handy manual =)
Old Sep 2, 2004 | 12:02 PM
Red Rider
Check that owners manual, and you will see that it also recommends HP Trans Oil, as well as HP4 (without moly). My first choice for the trans would be HP Trans Oil, then HP4 (synth blend), and GN4 (dino oil) would be my absolute last choice. In the engine, I run HP4M (a JASO MB oil with moly).
Where I live it is hot, and I would rather have the protection of an 80W/85W oil. If I lived in cold country, I would probably run Honda HP4 10W-40 in my trans for the winter. (If you go to Honda's Canadian web site, there are also some lighter winter oils available.)
See this article is you have not already. Everything that pertains to the CRF's, also goes for the 450R.
http://www.thumperfaq.com/oil.htm
Old Sep 3, 2004 | 09:17 PM
jeepnrocks's Avatar
my dealer gave me hp4 for both sides synth blend. i cant wait to change it out i want regular tranny oil in there also
cornermike
Aug 10, 2016 06:47 AM
Albertaboyy
Sep 9, 2015 09:51 AM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
Elkaholic
Sep 6, 2015 02:44 PM
