QUICK the ds is on its side. The last clutch plate??
Old Sep 9, 2004 | 03:52 PM
crackerJack's Avatar
Default QUICK the ds is on its side. The last clutch plate??
Someone told me the last clutch plate goes on offset from the others. It this true and is one of the plates different so its teeth will fit in that smaller groove??? I can't get any of the discs to fit offset and the bomb dealer did not offset that last plate? quick response if possible. thanks
Old Sep 9, 2004 | 03:56 PM
What torque for the clutch bolts?
Old Sep 9, 2004 | 04:12 PM
CountryJoeGlass's Avatar
The clutch spring bolts are 89in lbs if I remember right.
Old Sep 9, 2004 | 08:16 PM
busmechanic's Avatar
when I did mine the "odd" plate looked a little different than the rest. there was no geussing. it was barnett though. it fits pretty tight. you may just need to go through them again to find the odd one.
I agree with countryjoe on the torq. spec. 89in lbs or 10NM. same for the side cover.
Old Sep 9, 2004 | 08:46 PM
SANDMAN430's Avatar
the last one needs to be off set or it will slip. how was the actuator. make sure you use inch pounds and not ft. pounds.
Old Sep 10, 2004 | 12:03 AM
The first plate was not offset>(local bomb dealership mess-up) the actuator looked great. The first four plates were a little burnt but the inside 4 looked great. I roughed them up a bit and put it back together. It worked great. No more slipping even up a concrete incline turbo engaged in fifth gear. I leaned it out a little and it idles alot better and the lower RPMs are way more peppy. Alot snappier than the stock set up. Anyone know why not offsetting that first plate causes it to slip? It looked like it was suppose to be offset to stop damage from occuring to the plates if the clutch plates were worn to metal.
Old Sep 10, 2004 | 12:15 AM
SANDMAN430's Avatar
glad to hear that fixed that, how you going to fix that light front end now?[img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 10, 2004 | 12:17 AM
I might put a 4" swing arm later but I do alot of cross country racing, trailriding and duning. It did feel good having to lean forward in fourth gear up the sand. I might just put one of the patients tractor weights on the front bar lol.
Old Sep 10, 2004 | 12:31 AM
DuneMe's Avatar
[img]i/expressions/face-icon-small-confused.gif[/img]
That last plate shouldn't have to be offset. I've run it without being offset for over a year and I know Jeff and many others do the same.
Regardless. . . glad to hear its working again!
Oh, my understanding is that last one is offset to let you know when your clutch plates need replacing. When it starts to slip the plates have worn to where they should be replaced (clearances too much.)
Old Sep 10, 2004 | 12:37 AM
I gotta tell everyong that during a busy work day while in the office dealing with customers and constant phone call Duneme took a half hour at least to walk me through the problem I was having this morning. He even took pictures and walked me through the different things to look for. That is what this forum thing is all about. Good guys helping us stupid new guys out. thanks a ton to everyone who has helped. I am going to repay some of the favors when some of yall make it up here to st anthony. apple pie anyone????
