I need repair help.
Old Sep 11, 2004 | 01:04 AM
Bildo124's Avatar
Default I need repair help.
I am a fairly new rider and i just bought a 400 ex for a decent price. I noticed that i need to repair the bearings inside the swingarm. I have very little experience working on quads and was wondering if anyone would give me some hints on the best way to replace these bearings. Thank u!
Old Sep 11, 2004 | 01:11 AM
LittleBill's Avatar
unless you are mechanically able, i would highly recommend you take the quad to someone who knows what they are doing, because if its similar to my rancher, there is quite a bit u need to remove
Old Sep 12, 2004 | 10:06 PM
dustmaker's Avatar
it's easy you can do it...first clean the area as not to get dirt in there then take tires off then loosen big nut next to rotor then remove snap ring under nut then remove chain.. brake cal. and bracket then rotor then remove allen screws at rear of bering housing spray it up and wack it out good luck u can do it .....
Old Sep 13, 2004 | 03:49 AM
35Charlie's Avatar
Check here for more details.
EIF
Apr 20, 2017 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
Matt123
Sep 29, 2015 01:29 AM
2many2ride
Sep 27, 2015 04:35 AM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
