Grizzly 660 mods
Old Sep 12, 2004 | 05:43 AM
Ish416's Avatar
Default Grizzly 660 mods
Hi, my friend is wanting a little more power out of his Grizzly. I was thinking that since the top end of the Grizz is almost the same as the raptor that the same mods would work. I was thinking: high compression piston, something around 11:1, exhaust either full or slip on, K&n air filter, rejet the carb and maybe a more agressive cam. With doing this would he also need to put a different spring in the auto tranny? I don't know alot about cvt's so any help would be appreciated. He also plans on running 25 or 26 inch tires.
I know that on raptors that by opening up the intake and exhaust that you can get a pretty decent gain in power, something like 8 horsepower and I have also heard that they respond really well to higher compression, I was just wondering if this is the same on the Grizzly. If so, I will ask to ride it and just leave and never come back . [img]i/expressions/face-icon-small-happy.gif[/img] Anyways, thanks for any input you have.
Old Sep 12, 2004 | 01:26 PM
Sparky660's Avatar
The piston and cam really wake this thing up I would definately go for it. As for the larger tires I would go with and EPI clutch kit. I would also phone EPI if you are going to do the engine mods as they suggest going with different clutch weights depending on power outputs. Or if adding the larger tires get the oversize tire clutch kit. The exhaust that I have helped out greatly.
Old Sep 12, 2004 | 03:56 PM
minimus's Avatar
Are there aftermarket ignition modules or new cdi for a grizz?
I looked on dynatek and found nothing, can't remember if highlifter or Dg have modules.
Exhaust seem to be the least bang for buck with the Kawi utilitys. Can't say if there is a big increase with the grizz.
Customer Service #1
May 15, 2020 08:46 AM
cboler9
Sep 24, 2015 08:35 PM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
