raptor valves
Old Sep 12, 2004 | 03:05 PM
duke9074's Avatar
Default raptor valves
is it really neccasary to adjust your valves on a four stroke atv (like the raptor) becusase on a four stroke car you never adjust the valves soo why do you need to don that on an atv what makes it different?
Old Sep 12, 2004 | 05:22 PM
caliraptor's Avatar
Yes it is necessary to adjust the valves...unless you want to mess up the head/valves/have lack of power/hard starting and a noisy engine. I changed out my valves a couple of months ago and can take a pic of a valve so you can get an idea of what happens when you dont adjust them.
Old Sep 12, 2004 | 06:39 PM
duke9074's Avatar
ok thanks
Old Sep 12, 2004 | 07:46 PM
HappaRap's Avatar
Lazy Boy Rider!
Yep, adjust them or you'll find out what could happen [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Sep 12, 2004 | 07:48 PM
sixsixT's Avatar
Most cars have hydraulic valves and don't need to be adjusted once there set. Most 4 stroke ATVs have mechanical valves and need to be adjusted.
Old Sep 12, 2004 | 08:13 PM
caliraptor's Avatar
on old school engines with mechanical lifters you had to adjust the valves very often..but with hydraulic lifters u pretty much didnt have to adjust them, just once. Since the rocker arms on the raptor work right off the cam lobes, you can say it pretty much works like a 350 chevy with mechanical lifters, just adjust them and be glad you did the maintenance and ur quad will give you years of fun and stress relief
Old Sep 12, 2004 | 09:24 PM
warwgn's Avatar
the valves wear easy, the intake are not hardend so they wear out and reduse your valve clearnce, thats why the intake valves alway get tighter, while exhaust valve are hardend and dont need to be adjusted as often as the intakes, but you should check them at the same time. If you dont adjust them they wont open and close fully or in time with the spark so you will loose power.
bmxatv10
Oct 14, 2022 06:23 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
