Pro Design Pro-Flow filter for Banshee??
Old Aug 24, 2000 | 12:30 AM
rottwolf's Avatar
Hello all. I'm curious if someone will run down their cleaning process with this foam filter for me. Do you oil the slip on second stage and the yellow body filter too? I've used the aerosol spray foam cleaner(PJ1) but it sure takes at least a can to clean it, more actually. Is there something better or more cost effective to clean it?
Thanks for your help,
Jason
Old Aug 24, 2000 | 01:32 AM
4trxRman21's Avatar
only oil the outer slip just to trape dirt i usely wash my filter's with soap and water oil with any light spary lub now ride 86 tricked out 4 trx 250R and 86 atc 250r former owener of 85 250 big red es /88 300 4wd honda 4trx /400 forman /98 banshee /90 250X
Old Aug 24, 2000 | 06:19 PM
garyc660R's Avatar
I normally use a grease-cutting dishwashing detergent like DAWN. As cheap as it is, you can clean the filter often, keeping the filter from getting too dirty while keeping power at it's maximum. I have never used that type of filter, but it seems that if you only oil the outer layer, and make sure the intake tube stays clean, you should be OK.
Sep 30, 2015 01:37 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
