95 425 Magnum 4x4 , some questions
Old Sep 14, 2004 | 11:38 PM
gross's Avatar
Default 95 425 Magnum 4x4 , some questions
getting ready to change oil, filter, and gear lube,,,
is there anything that i can use safely to flush, the crankcase, oil tank and gear case ?
also, on our 93 350 2x4 , the clutch seems to be rubbing the clutch cover, i have ordered one, but i noticed that one of the bolts that hold the inner clutch cover on is missing, the only spec sheet i have just says bolt,, does anyone know what size ??
thanks,,,,,,,,,,
Old Sep 14, 2004 | 11:50 PM
Bradracer18's Avatar
ok....to start with, good job with doing great checkups. On the oil, use the oil you are going to put in the quad, and flush it out with that, you don't have to use much. I used to run Bel-Ray oil in my gearcase, and counterbalance, and Polairs in my oil resivor. As for the cover, it was probably warped due to heat, and it only does good to get the inside and out if you are going to do it right. The bolt you should be able to get at your dealer too. They are probably metric, or a screw type. Also, make sure your clutches are in align before you put on the cover......I don't know how to do this, but someone on here does, just ask another question.
wendal
Oct 31, 2017 03:31 AM
bigred20653
Oct 2, 2015 10:05 AM
greg86hd
Sep 16, 2015 12:32 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Sep 9, 2015 06:57 AM
