Blaster shifting problems
Old Sep 15, 2004 | 06:24 PM
hawleywood's Avatar
Default Blaster shifting problems
my buddy just got a used blaster rode a day or two and now it seems it is stuck in neutral and clicks pretty loud going up or down any suggestions from the Yamaha guys
thanks
p.s and I searched the yamaha forum before asking and could not find anything with this problem
Scott
Old Sep 15, 2004 | 07:12 PM
YamahaRider05's Avatar
I would check to see what condition the clutch is in, if it is still working, and how much oil he has in the crank case.
Old Sep 15, 2004 | 07:21 PM
hawleywood's Avatar
the clutch is on its last thread but when you shift it up or down it just clicks with no end.
sorry for the ????have not work on a clutched bike since the old 87 quadracer
thanks
Old Sep 15, 2004 | 07:24 PM
can you describe EXACTLY what happens in as much detail as you can? It would really help me find a solution to the problem, thanks
Old Sep 15, 2004 | 07:37 PM
hawleywood's Avatar
thanks for your time
when the bike is started the bike seems like it is in neutral,when you pull the clutch put in gear nothing.when it is turned off you can shift up or down like it is going into gear but it will go more than six clicks some local boy thinks it might be a bent shifting fork??
1.) the clutch isn't disengaging
2.) the shift forks are bent/siezed
3.) gears are sticking
That is what i think is wrong with your buddy's blaster. But that is just me
Old Sep 15, 2004 | 07:42 PM
If it is the forks then it was probably caused my overhaul on the transmission.
But here is what my manual says:
1.)Shift pedal broken
2.)clutch not disengaging
3.)Shift drum binding
4.)gears stuck on shaft
5.)shift mechanism pawls broken or worn
6.)pawl spring broken
number 6 from my manual sounds pretty likely too. It says if the pawl spring is broken then it would cause sporadic shift operation. Solution: replace spring
spo·rad·ic ( P ) Pronunciation Key (sp-rdk, spô-) also spo·rad·i·cal (--kl)
adj.
Occurring at irregular intervals; having no pattern or order in time. See Synonyms at periodic.
Appearing singly or at widely scattered localities, as a plant or disease.
Isolated; unique: a sporadic example.
hawleywood's Avatar
thanks again
tearing it apart this weekend while IVAN is pouring rain down in my part of the woods
Old Sep 15, 2004 | 07:48 PM
post here for some updates
And read my edited post (4th i believe)
Old Sep 15, 2004 | 08:02 PM
Just in case you didn't see this edit i made
adj.
