chain?
Old Sep 15, 2004 | 09:25 PM
dsracer650's Avatar
Default chain?
i have a 2002 ds650 baja. i need to kno how to tighten the chain? i kno someone here knows how to do it
Old Sep 15, 2004 | 09:28 PM
CountryJoeGlass's Avatar
Default chain?
there is a thread from about 5 days ago on this. you might try a search.
Old Sep 15, 2004 | 10:27 PM
dsracer650's Avatar
Default chain?
ya dont c it anyone kno how 2 do it?
Old Sep 15, 2004 | 10:34 PM
OregonDunePatrol's Avatar
Default chain?
Ok I'll attempt this ..
1) Put the DS rear up on blocks - under the swingarm away from the chain
2) Losen the rear bolts on the carrier clamp.
2) Find your chain tightening rod in your tool kit - It looks like a screwdriver shaft with no handle or end.
3) Put the tightening rod through a small hole on the sprocket hub.
4) rotate the hub by turning the tires, and push the rod into one of three holes on the stock carrier.
5) Once the rod is through the sprocket hub and in one of three holes on the bearing carrier, rotate the tire, with the bearing carrier forward or backwards until the chain is tight (allow about an inch of play in the middle of the chain). This tightens the chain because the carrier is oblong.
6) Tighten back up the carrier bolts.
If this does not fix your problem, you probably have bearings out in your carrier -
Old Sep 15, 2004 | 10:37 PM
Default chain?
OPPS taken care of! Nice job OregonDunePatrol!
Old Sep 15, 2004 | 10:57 PM
Mrneg9's Avatar
Default chain?
I read your post on how to tighten the chain. I just bought an 04 ds650 Baja X. The dealer set up the chain for me this way. He told me it takes two people. He said I had to be sitting on the bike while he loosened the four bolts and adjusted the chain. Is this right ?
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
