BOUGHT ANOTHER LEM CAYMAN
Old Sep 16, 2004 | 05:56 PM
racingfamily's Avatar
Default BOUGHT ANOTHER LEM CAYMAN
Hey I bought another 02' cayman this weekend. went to new york to get it. It has +3 a-arms douglas wheels, holeshots nerk bars, alum. cyl, r&d pipe about everything. but now I would like to find someone who makes a wider and stronger rear axle. I also found out that workjs makes shocks for these quads they cost $319 for the front and $259 for the rear. By the way what size carb is everyone running and where can I find it and maike marion says I can get a 70cc jug for this s5 motor but haen't found it yet. Gimmie some input please.
Old Sep 18, 2004 | 03:07 PM
SteveMarolda's Avatar
It's become almost impossible to find big-bore S5-N pistons because of it's piston-port design. 60cc pistons but to go beyond that you need to change to the S5-GS reed-valve cylinder and head. But then the downside with that is you have to make your own exhaust. Either way you will also have to change to different carburetor. Not that it needs a bigger carburetor bore size but the bigger engine will drain the float bowl faster than it can refill. It will run out of gas and stall on the longer straightaways. It's all do-able but it's a bit of work.
Old Sep 19, 2004 | 01:42 AM
I should have said that I knew about needing the reed style cyl. when I posted, but even at that I don't know where to find one. As far as the pipe goes I was told that this r&d pipe would work because it has the spring hooks on it already. But I still want to find whatever it is I can get for this quad even if I need to change to the s6 ac motor before next season starts I will. But I can tell tou that I can go up to 79cc and still run the 50cc modified class next year.
REMEMBER WHAT THEY SAY YOU CAN ONLY GO AS FAST AS YOU CAN AFFORD !!!!!
Old Sep 20, 2004 | 02:02 PM
The cheaper way is to find a used, damaged cylinder to modifiy. You just have to do some searching. Action in Florida sometimes has used parts for sale on Ebay. If you are lucky you can find them already modified.
Old Sep 20, 2004 | 03:49 PM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Have you tried this guy? Heard pretty good things.
Robbs Racing
Old Sep 20, 2004 | 04:16 PM
There's a used cylinder and head on Ebay right now for only $20.00!
http://cgi.ebay.com/ebaymotors/ws/eB...489910863&rd=1
Perfect starting point.
Old Sep 21, 2004 | 06:53 PM
racedad26's Avatar
We also have a cayman that is done. plus 3 plus 6 rear end with 1 inch axle, ac a-arms ,nerfs and the list goes on and on.
COFatboy
May 2, 2020 12:06 AM
Jordanl6112
Aug 3, 2015 10:19 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
carolinabomb
Jul 26, 2015 08:40 AM
