Oils for 400ex
Old Aug 24, 2000 | 07:02 PM
400exrydr's Avatar
It's time to change the oil and I was wondering what brands/types other people use. I was looking at Maxima or Bel Ray 15w50. What do you think?
Old Aug 24, 2000 | 10:45 PM
x400ex's Avatar
I RUN AMSOIL
Old Aug 24, 2000 | 11:08 PM
86atc250r's Avatar
Any of the higher quality synthetic or synthetic blends should work nicely, I would use 15w50 or 20w50.
I use Mobil1 15w50, the price is right, the specs are right (quality blend of base stocks, no friction modifiers, no viscosity index improver), and it's easy to obtain (Walmart).
Old Aug 25, 2000 | 01:04 AM
Skunky's Avatar
I use pro honda hp4 gold bottle 20w-50 for the hot hot weather here in vegas... man its hot... not bad today though got up to 100
Old Aug 25, 2000 | 01:05 AM
Skunky's Avatar
I use pro honda hp4 gold bottle 20w-50 for the hot hot weather here in vegas... man its hot... not bad today though got up to 100 it is starting it's downward cycle Darn please delete top one atvbbs
Old Aug 25, 2000 | 05:26 AM
Fixxxer78's Avatar
I use Valveline full synthetic 20w-50. I live and ride in the Imperial Valley so it’s even hotter than Vegas. It was so hot the other day I had to adjust the idle screw because the fuel was evaporating before it could be burned when idling. It’s been really humid lately because of the hurricane leftovers so it's cooled off a little.
Old Aug 25, 2000 | 06:01 AM
JRM's Avatar
JRM
Bell ray 20W50 snythtic or Honda HP-4 20W50
Under 50 degrees I run 20W 50 Amsoil series 2000
Old Aug 25, 2000 | 08:10 AM
briancwatkins's Avatar
Just picked up two 6-pack cases of Castrol Synthetic Blend 20W-50 for a whopping $29 (for both not each).
I actually was wondering the same thing 400exrydr. Wasn't sure if what I got was good enough or not. I tried finding %100 synthetic, but didn't have any luck. It's hard to find 20W-50 all synthetic.
I change the oil about every 3 tanks of fuel. How about the rest of you?
Old Aug 25, 2000 | 11:52 AM
tprender's Avatar
Just remember that Honda does not make there oil, they buy someone's elses and put there name on it. The manufactor might change from year to year. Also, we have done some big bore kits and the directions from the Web cams says don't use Synthetic oil. Use regular oil and change it offen.
Old Aug 25, 2000 | 12:07 PM
Wonder why you shouldn't use synthetic?
