brute force suspension settings?
Old Sep 18, 2004 | 01:43 PM
lyle1's Avatar
Default brute force suspension settings?
With a set of ATR tires, what suspension settings are people using...210lb rider trail riding and hill climbing? I have heard that the Brute Force is spring fairly stiffly, so running nearly the softest setting in the back with about #3 in the front to combat front end "pushing" is a good bet. I guess you don't want it too soft in the back though, so the back doesn't squat when aggressive hill climbing. Anu help would be appreciated.
Old Sep 18, 2004 | 11:02 PM
redbruteforce's Avatar
I know this isn't much help but that is one of those things you got to mess with on your own to get it the wat you like it. I would start in the middle and try it a setting stiffer all the way around, and then a setting softer than the middle setting and see which treated you best. You want it to absorb bumps but not lean to bad when on a off camber side hill. I like mine at the second softest setting in the back and the middle in the front, seems like a good balance for me
ylomnstr
Sep 22, 2015 12:19 AM
awer1968
Sep 8, 2015 11:02 AM
chewy78
Sep 8, 2015 10:37 AM
Elkaholic
Sep 6, 2015 02:44 PM
ylomnstr
Sep 4, 2015 05:02 PM
