Air filter cleaning
Old Aug 25, 2000 | 12:11 AM
rmx251's Avatar
what is the best way to clean a foam air filter? I have been told to soak it in gasoline for awhile.
Old Aug 25, 2000 | 12:25 AM
hot_shoe_cv's Avatar
NO!!!
Aside from the obvious extreme fire hazard, gasoline can damage or destroy the adhesive used in manufacturing the filter.
Some like to use detergent & water. I prefer using a water soluble aerosol spray which can re rinsed out in the kitchen sink with no residueleft in the sink. There are several brands of foam filter cleaner, Uni and Maxima are two I use interchangeably with very good results. Both of these brands also make filter oil and seem to be equally good at trapping dust. I like Maxima the best because the cans are bigger.
Old Aug 25, 2000 | 05:13 AM
chriscoll1's Avatar
Use uni filter cleaner first to get the oil out, rinse it.Then use Dawn dish soap to get it clean.Rinsing it with warm water is better if you can do it.Just make sure the old lady isnt around to see you cleaning filters in the sink!
Old Aug 25, 2000 | 10:59 AM
THEXOTIC1's Avatar
We use PJ1 foam cleaner. IF you do it right you do not need to wash it with soap. Hey chriscoll1
email me and let me know where you ride. I see you are from cherry hill NJ. also take a look at the site in the signature. we do alot of riding in NJ and PA.
Old Aug 26, 2000 | 05:33 PM
88trx310R's Avatar
I have been told that kerosene works for cleaning foam filters. its not as strong as gas so it wont break down the filter like gas would. I recently cleaned my filter and i: took the prefilter off, cleaned it w/ kerosene, cleaned it in warm soapy water, let it dry real good, cleaned the uni filter w/ kerosene then warm soapy water and let it dry fully also. i then sprayed Foam Filter Oil on both the filter and outerwear. Putting oil back on the foam filter is very important because it is what catches most of the dirt.
Old Aug 26, 2000 | 11:41 PM
steve250R's Avatar
i use mineral spirits and it seems to work good. anyone else use mineral spirits?
Old Aug 27, 2000 | 12:23 AM
ATV_MAN's Avatar
Well I start by soaking it in Gasoline...then I wash it off with soap and water then I blow dry it till it's completley dry and I'm done.
A cheap way to clean you filter!!
Old Aug 27, 2000 | 12:50 AM
ScoobyDFW's Avatar
I use liquid Tide w/bleach alternative.
COFatboy
May 2, 2020 12:06 AM
cody500ho
14
Aug 14, 2015 05:03 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Aitch
Jul 21, 2015 09:40 PM
