Will i run to lean or rich?
Old Sep 19, 2004 | 06:26 PM
Warrior453's Avatar
Default Will i run to lean or rich?
i just took the baffle out i think it sounds good and a little better throttle responce but will i run to lean or rich? (I plan on runnin it like this till christmas)
Old Sep 19, 2004 | 07:09 PM
Doctorturbo's Avatar
GOT BOOST!
You will run leaner with the baffle out.
Old Sep 19, 2004 | 07:11 PM
Warrior453's Avatar
yea but will it hurt the engine or anything else?
Old Sep 19, 2004 | 07:30 PM
GOT BOOST!
That's tough to answer, and I will tell you why:
99.9% of the time you will be fine because most engines are jetted a bit rich from the factory. Now lets say you are a sea level and it's a nice cool day with lots of 02 in the air and you are jetted a bit on the lean side to begin with............... your going to be picking aluminum out of your exhaust port.........you get my point.
Here is a down and dirty way to know if you are rich or lean. I your engine starts without a choke when it is cold, your fine and quite a bit rich. If you start it up and it idles rough or dies without a choke, then you are right there on mixture. If you need to choke it for a long time after startup then you are lean to begin with.
All in all, I would yank the baffle and have fun. Keep an eye on your plug and you'll be fine.
And all this crap about burning valves and all of that; it's just that, crap.
Old Sep 19, 2004 | 07:32 PM
Warrior453's Avatar
well today in upstate ny it was like 60 and a bit windy it started without the choke fine so i think i should be ok. thanks for the help
Old Sep 19, 2004 | 08:48 PM
maddog56's Avatar
60 degrees is one thing, but when its 30 it will be a different story. And it gets a lot colder than that up in NY. If you arent choking it a lot, its not backfiring and the plug looks good then you should be ok. You can always tweak the pilot a little too.
Doc, glad to see you around and still helping on jetting issues.
Old Sep 19, 2004 | 09:12 PM
Warrior453's Avatar
well when i first started it today it backfired as soon as i started it and that was when i gave it the gas and that was the only time is this an indication that im runnin to lean?
Old Sep 19, 2004 | 09:33 PM
hondabuster's Avatar
You could try going out on the mixture screw, about 1/4 to 1/2 turn. This will help the backfire/ cold start symptoms. Heres an article on jetting and drivability symptoms of lean and rich.
jetting
Dammar
Apr 20, 2016 06:03 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
bvolks
Sep 13, 2015 12:57 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
