Sport Quads Discussions on sport quads.
retapping stripped thread
Old Sep 21, 2004 | 09:29 PM
whitebroskfx440's Avatar
Default retapping stripped thread
my friend has a yfz and he has stipped the thred on his swing arm where the skid plate would go..i have a tapp and dye kit how do i retap it what do i use do i just spin it in the hole or what do i do
thanks
Old Sep 21, 2004 | 09:32 PM
Bradracer18's Avatar
You are probably going to have to go to the next size larger.....you can try just tapping it out, but my guess is you will have to drill the old threads out, and retap them again with the size reccommended on the box(or size that fits).....don't forget to use lube, and take it slow.....also no drills to tap with, use the hanlde thingy.
Old Sep 23, 2004 | 08:30 PM
ostrich's Avatar
There is no harm in trying to chase the stripped threads, you can't wreck them twice! if the origin of the threads are ok you'll be ok, other wise drill it out the next size and use the tap handle to spin the tap
Old Sep 26, 2004 | 11:45 AM
thewayout420's Avatar
be sure when your tapping it that you take little bites at it,screw it in a half turn then back out and repeat untill its finished..
ultangler
Nov 30, 2024 01:35 AM
bmxatv10
Oct 14, 2022 06:23 PM
EIF
Apr 20, 2017 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
tysonbully
Sep 28, 2015 02:30 AM
