how fast is a stock 05 7oo prairie supposed to go?
Old Sep 24, 2004 | 02:34 PM
cookerwon's Avatar
Default how fast is a stock 05 7oo prairie supposed to go?
jusy wondering what your prairies do for top speed, my 05 will do about 60 - 64, it depends on the the day as far as temp and that is on flat pavement. ive also have 6 ply itp 589 26" tires on it.
Old Sep 24, 2004 | 07:28 PM
LittleBoy's Avatar
A normal Prairie 700 does between 65 to 69 mph stock, but seeing you have 589s they consume a lots of power from the engine. So, a 5 mph lost is normal in your case.
Old Sep 24, 2004 | 08:16 PM
redbruteforce's Avatar
keep in mind that your speedometer is no longer correct, with the taller tire the speedo is registering a slower speed than you are actually traveling, a 1" difference probably means around a 2 mph difference, then you have the extra rotating mass of the tires whichs takes away some of the power.
Old Sep 25, 2004 | 09:50 AM
ND's Avatar
ND
Of course, the speedometer was likely incorrect to begin with. If you checked it with a GPS and it was accurate, figure out the percentage change in tire height and add the same percentage to your final speed. So if your tires are 2% taller and your accurate speedo reads 64, actual speed will be 65.28.
FWIW, my 03 with stock tires and black spring being the only mod runs 65-66 (gps) on flat dirt on a good day. Low 60's on any given day. Aren't limiters great?
slowgsxr97
Mar 18, 2022 03:40 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
DGNAZ
Sep 5, 2015 09:14 PM
toonces
Sep 5, 2015 01:14 PM
coolguy420
Jul 9, 2015 09:54 PM
