The Ricochet System IS IN!!!
Old Sep 24, 2004 | 03:27 PM
dogg's Avatar
Default The Ricochet System IS IN!!!
I just installed the Complete Ricochet Skid Plate System on my P700! The pictures are on my page. It took about an hour to install them. Now I am ready for ROCKaway!!!!
Old Sep 24, 2004 | 06:26 PM
grizzkiller's Avatar
nice job, they look real good, i'm gonna need some for the brute.
Old Sep 24, 2004 | 09:45 PM
pads's Avatar
I just installed the same set-up on my Twin Peaks. I was going to post a warning for who ever has the Swing arm skid. Put the stock bolts back in the swing arm. Those holes go right up into the drive shaft housing. Without the bolts water will be able to get into the housing. I don't remember seeing that in the directions. I am going to call Ricochet and let them know so no damage can come to any machines.
Old Sep 24, 2004 | 10:08 PM
dogg's Avatar
Are you talking about the front A-arms?
Old Sep 24, 2004 | 10:10 PM
pads's Avatar
No, the rear swing arm. The two bolts closest to the motor side that you removed in order to take off the stock skid plate. After you remove the stock plate, put the bolts back in to avoid getting water in.
Old Sep 24, 2004 | 10:16 PM
dogg's Avatar
Pads,
I'm not understanding your post. The swingarm mount is the rear mount. It is mounted using the differential bolts that are already there. Are you referring to the bolts that you had to take out? I think they were the 8mm heads. I will check it tomorrow. Thanks for the heads up!
Old Sep 24, 2004 | 10:31 PM
pads's Avatar
The bolts are the ones threaded up into the swingarm on the underside of the swingarm, not the differential bolts.
speedbuff
13
Nov 11, 2020 10:16 AM
Oct 10, 2015 10:20 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
