how many lbs of compression should a 2000 ds 650 have?
Old Sep 27, 2004 | 01:29 AM
jackass650's Avatar
Default how many lbs of compression should a 2000 ds 650 have?
i am gonna do a comression test on it in the morning thanks fellas
Old Sep 27, 2004 | 01:47 AM
jackass650's Avatar
someone has to know the answer dont they? none of you guys know how much compression you should have on a good used ds650?
Old Sep 27, 2004 | 02:03 AM
BlackHawk's Avatar
Do a search, I know it has been discussed before. I know ThePunisher made some posts on the topic at one point.
Old Sep 27, 2004 | 02:45 AM
TheChosenOne's Avatar
My '04 hit between 150-160... This may help may not, but i tried.
Old Sep 27, 2004 | 03:54 AM
BlackHawk's Avatar
TheChosenOne,
When you got those numbers, was the automatic compression release enabled or disabled? I'm pretty sure with the compression release disabled, it's supposed to be somewhere in the 200s, but I don't want to give out any bad info since I don't know for sure.
Old Sep 27, 2004 | 04:29 PM
It wasn't disabled, I just hooked up the computer to one of the sparkplug inlets, and ran a 15 second test with full charge, and that was about my average.
Old Sep 27, 2004 | 04:57 PM
Prozack's Avatar
how do you disconnect the auto comp. release????
Old Sep 27, 2004 | 06:47 PM
DCryder's Avatar
To deactivate decompression lever you have to take the valve cover off, push the lever up out of the way, and I stuck a toothpick in it just firm enough to hold it.
Also good idea to go ahead and check valve lash before doing the test while the cover is off in case it has lost clearance because intake valves can stay open when lash is lost.
Mine made 160 lbs with decompression lever working, made 180 lbs without. But this is with 12.5:1 piston and WEB 109 cams.
Old Sep 27, 2004 | 09:07 PM
crackerJack's Avatar
Did you guys all have your throttle wide open when getting these numbers??
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Dammar
Apr 20, 2016 06:03 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Myronh
Sep 8, 2015 11:27 AM
