question on '04' 400 4x4 man.
Old Sep 27, 2004 | 04:32 PM
SHAWNSCAT's Avatar
Default question on '04' 400 4x4 man.
its new only 170 miles on it .
when i turn the key on should all the lights come on in the pod. (its not digt.)
the only one that dont come on is the oil light all the rest work fine .....just wondering ........
one more thing i have a knocking sound in the motor
it doesnt seem to affect it at all runs great
i love it
Old Sep 27, 2004 | 08:03 PM
pvwheeler's Avatar
the oil light doesnt work on my wifes 04,nor did it work on my 03 400.According to the wiring diagram in the 03 service manual, the wiring doesnt exist.There is an oil temp light though?
Old Jan 7, 2005 | 11:11 PM
SHAWNSCAT's Avatar
I have never had the oil light come on and I was wondering if the light works at all. Is there anyway to check if the light is working or if its not even hooked up like pvwheeler said. Why would they even have it if it wasn't used? It would be a nice feature cuz U never know if the oil leaked out while u was riding hard. Thanks for anyone who knows about this.
Old Jan 7, 2005 | 11:18 PM
pvwheeler's Avatar
yeah seems really stupid to me too[img]i/expressions/face-icon-small-disgusted.gif[/img]
I would much rather know if I have oil PRESSURE than if the oil is hot....
Old Jan 7, 2005 | 11:23 PM
SHAWNSCAT's Avatar
i was thinking that too. why bother if its useless
Old Jan 8, 2005 | 10:29 AM
Nats's Avatar
I would contact your dealer or go to www. arctic-cat.com website. Seems like an inportant thing to know.
Old Jan 9, 2005 | 06:10 PM
Bear4570's Avatar
So install a oil pressure switch and wire it in. All you need is a "T" in the oil line where it comes out of the engine to the cooler and run a wire to the plug for the oil lite and Bingo! you have what you want. But be warned, the likely reason they don't do this is a standard oil pressure switch is 10 to 15 psi and you may find that when warm and at idle you engine may run as low as 5 psi and your lite will come on. In that case you get to try and find an adjustable switch or a low psi switch.
Old Jan 9, 2005 | 08:24 PM
ArcticBrat's Avatar
SHAWNSCAT When do you hear the knock in your motor? I also have a 04 400 manual shift that knocks has 650 miles on it and has knocked from day 1 works great but don't like the noise. The dealer said it was the clutches working but sounds to me like the top end.I get the knock when the engine is lugging. Any idea's?
Old Jan 9, 2005 | 09:22 PM
Bear4570's Avatar
If it was a rod or piston knock you would have broke something by now. First off you shouldn't lug the engine, it's hard on them and the rest of the drive train and that's what the shifter is for, so you can down shift and get the engine back in it's power band. When you lug and engine the throttle is wide open at low rpms cause a rich condition and a lot of unburned fuel gets dumped into the exhaust where they burn and make noise. Also the deive train componets clatter alot when the engine is lugged. The only sound my '05 400 makes that I don't like is the gear whine in 4th and 5th gear, but like you I was told it is normal.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
