clicking noise from right rear suspension/tire area of brute force
Old Sep 28, 2004 | 07:59 PM
idahopraire's Avatar
Default clicking noise from right rear suspension/tire area of brute force
I have a clicking noise coming from the right rear suspension area of my brute force, if I press down on the rear rack I can get it to click, or if I take the right rear tire and wiggle it lateraly it will click. Does anyone else have this noise?? All bolts and nuts are tight.
Old Sep 28, 2004 | 08:18 PM
newbeatle's Avatar
Sounds like you need to change the swing arm bearings... look at NYROCS or KISSOFDEATHS web sites for good info... ( it will be basically the same proceadure as the Prairies...
Old Sep 28, 2004 | 11:04 PM
nyroc's Avatar
Newbeetle, that is IRS. No swingarm bearings (unless it is a Brute Force 650, ha ha).
Idahoprairie, you may have a bad wheel bearing, or you may have bad bushings, or you may have a loose spindle nut (but nut), or the clearance between the bearing and the knuckle is loose.
Old Sep 29, 2004 | 08:20 AM
newbeatle's Avatar
NYROC... you are right... I'm Bad... I swear it said V Force last night, at the end of a long day ??? Maybe the sun was in my eyes ??? you're not buying it are you...
Old Sep 30, 2004 | 12:56 PM
Alucard's Avatar
Check some of the other problem area BF posts. Other owners were comparing notes about the left CV boot cracking and causing a clicking noise. Might be the same problem with the CV boot, but on the right side...
greg74
Sep 10, 2019 03:03 PM
ronnierhino06
Nov 9, 2015 12:56 PM
velcro7279
Aug 24, 2015 01:15 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
Chuck188
Jul 17, 2015 02:45 PM
