raptor problem (please help)
We need a little more info . When did it start ? Has anyone worked on the carbs at all? did it sit for a long period of time? .
You might check the carbs see if there is think in the bowls check the jets make sure there clear
Inspect the needles make sure there smooth and working .
Goos place to start . Also make sure your air cleaner is clean and not restricted
Check common stuff like fuel lines and so forth, hope into the carb and see if it is dirty or a jet may have came loose. You can also adjust your valves, it helped me get 50% of my power back.
