raptor problem (please help)
Old Sep 30, 2004 | 02:26 PM
mikie67's Avatar
Default raptor problem (please help)
I have an 01 raptor that is fully stock. it is bogging down in high 2nd gear and up, first i thought it was out of gas but it was fine. anyone know what the problem is.
Old Sep 30, 2004 | 03:10 PM
Outlawlawndragster's Avatar
We need a little more info . When did it start ? Has anyone worked on the carbs at all? did it sit for a long period of time? .
You might check the carbs see if there is think in the bowls check the jets make sure there clear
Inspect the needles make sure there smooth and working .
Goos place to start . Also make sure your air cleaner is clean and not restricted
Old Sep 30, 2004 | 03:52 PM
kingofthetrack's Avatar
or drain the gas and put new gas in. sometimes it can be as simple as that hope that helps
Old Sep 30, 2004 | 04:08 PM
Jibrille's Avatar
Check common stuff like fuel lines and so forth, hope into the carb and see if it is dirty or a jet may have came loose. You can also adjust your valves, it helped me get 50% of my power back.
Old Sep 30, 2004 | 04:57 PM
Rider1169's Avatar
yes, air filter is a major thing there. the same prob happened to me and it was becasue my filter was clogged, there is a good place to strat
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
