adjusting valves
Old Oct 3, 2004 | 03:27 PM
350wolverine's Avatar
Default adjusting valves
can somone tell me how to adjust my valves, and what tools i might need?
Old Oct 3, 2004 | 05:05 PM
Jibrille's Avatar
You need valve feelers, and whatever tools it takes to get to the valves.
Asking these questions, you really shouldn't even think of adjusting your valves. take it to a shop and get it done.
Old Oct 3, 2004 | 07:07 PM
blindside350's Avatar
Dirt Wheels had a whole article on it this month (or the time before that not sure) you should try picking one up
Old Oct 3, 2004 | 08:09 PM
LotusPosition's Avatar
Coincidentally, I just did mine today.......
Remove the front plastic and gas tank. Set the flywheel so that the "T" mark is showing, on the compression stroke. Using feeler guages, set the intake valve to .003 and the exhaust to .007. If you have a service manual, it will give you a step by step procedure.
As noted above, unless you have some mechanical experience, it may be best to have someone do it for you.
Old Oct 4, 2004 | 01:44 AM
jibrelle, incase you hadnt read my earlier post, i stated I just rebuilt my motor,and have my ASE certification. figured id ask to see if anyone had some tips on easier methods.
Old Oct 4, 2004 | 02:03 AM
raptor8's Avatar
go to www.yamaha-motor.com you can now access owners manuals and stuff for free. check it out
Old Oct 4, 2004 | 10:39 AM
HoundDog06's Avatar
It's simple 350wolv. You will have to start by removing the front plastic and the gas tank. If I remember right, you have to remove the clutch cover on the wolvy to get to the crank nut. Rotate the crank nut till you achieve top dead center (see owners manual). Then remove the valve covers. You will need an 8mm wrench to loosen the jam nut. Then, simply turn the rocker seat in or out till you get the correct clearance (see owner's manual). When you acheive this, tighten the jam nut back down and replace the covers. Then the tank and plastic and your done.
~HoundDog
Old Oct 4, 2004 | 11:35 AM
sAyIt_fmf's Avatar
I would adjust them the same way you did when you just rebuilt your motor ?
Old Oct 4, 2004 | 06:34 PM
Ummm, you don't have to remove the side cover, you either take the plug out to access the nut, or on the pull start version, use it to rotate the flywheel to TDC. Removing the spark plug makes the rotations easier.
The jamb nut requires a 10 mm wrench. [img]i/expressions/face-icon-small-smile.gif[/img]
freeman34
Jan 8, 2016 11:46 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
