Recon 250 Problems
Old Oct 10, 2004 | 04:19 PM
fireman1324's Avatar
Default Recon 250 Problems
I have a Recon 250 that will start but will not remain running unless you hold the throttle down. It is a 2002 model recon. Has anyone had this problem or have any ideas of what maybe wrong?
Old Oct 10, 2004 | 04:54 PM
FastestBlaster's Avatar
i had the same problem with my 92 fourtrax 200! its sorta liek the recon but smaller. well the problem was that id be driving it but then id stop pushing the throttle and let it idle than it would stall. so my dad found the owners manual for it and come to find out that the switch on the gas tank said ON and OFF and it was on off b/c i thought it was for the reserve tank but it was for the fuel line to be on or off. so check out if you have a on/off switch fo rur fuel line and even check out if the reserve gas tank is on on or off. hope this helps!
Old Oct 10, 2004 | 04:59 PM
I have already checked the fuel supply valve and it is in the on position and the recon doesn't have a reserve tank. The recon has plenty of gas and is definitly getting plenty of spark. If anyone else has any other suggestions please let me know.
Old Oct 10, 2004 | 05:05 PM
oh well other than that all i could say is check the battery.
Old Oct 10, 2004 | 06:22 PM
RoscoePW's Avatar
is the quad warm? if i just start mine this will happen. once its warm its ok, check your oil levels, and try using a higher grade octane.
Old Oct 10, 2004 | 08:54 PM
I got it fixed. Somehow the airfilter element got soaked with gas and once i dried it out it fired right up now if I could find some decent tires for the back it would be great. Thanks to you guys for trying to help.
Old Oct 10, 2004 | 10:39 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Sounds to me like just a simple matter of to low an idle speed. Turn in the idle screw on your carb, a tiny bit.
Old Oct 11, 2004 | 03:07 PM
DarkManX's Avatar
thats what i say RECONRANGER is always rite [img]i/expressions/face-icon-small-wink.gif[/img]
Old Oct 11, 2004 | 11:26 PM
prieber14's Avatar
yup, thats what was wrong with my ex, idle was set to low when i first got it and wouldnt keep goin
Old Oct 12, 2004 | 12:44 AM
DarkManX's Avatar
YOU YOU YOU are the guy ive been looking for with the 250ex with the hand clutch that thing is a beast how fast it go ? whats it got on it ? god thats the nicest ex ive EVER seen!
inless u bought this from sum 1 else or i see a look a like!
