torque on the cam shafts
Old Oct 11, 2004 | 07:26 PM
jackass650's Avatar
Default torque on the cam shafts
do i have to buy a special socket to tirque it down? the bolt has an allen head on it, how do i use a torque wrench on it?
Old Oct 11, 2004 | 08:15 PM
amd's Avatar
amd
Are you talking about the actual cam gear or the cam retaining plate?. I will give you both just in case. Cam chain gear is 37 lbs ft. Cam retaining plate is 89 INCH pounds. Make sure you use an inch pound torque wrench or you will twist the bolt off in the head. Cam chain gear is 37 foot pounds which is a lot higher torque spec then 89 inch pounds.
Old Oct 11, 2004 | 08:44 PM
jackass650's Avatar
ok thanks
dannytas
Sep 26, 2017 06:31 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
01ssls1
Sep 22, 2015 06:50 AM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
